Backup Old Disks
persepolis
Backup Old Disks
Post by persepolis »
¡Hello!
I have a Hxc with a case (Blue Rev C) an a old Amiga 2000.
Its possible to backup my old Amiga disks to Pc?
I have a serial null modem cable connected between amiga and pc.
I have tryed to combine the floppy emulator with my real disk drive, but not succes. I have a old disk drive, the cable is with a double slot and twisted cable (at least at the end).
I put the original disk drive as df1, changing the jumpers, but didnt work...Any help?
thanks
Re: Backup Old Disks
persepolis wrote:¡Hello!
thanks
It seems that internal amiga floppy disk drives don't have the ID circuit, and cannot be used as DF1/DF2.
Your only way to use both drive is to put the HxC as DF1 and the internal disk drive as DF0.
persepolis
Thank you for your answer.
Then i have to put the jumper on ID2, Drive b as i put in red in the diagram bellow?
X X X X
X X X X
X X X X
