BBC Micro support (WORKING).
javidoom
Post by javidoom »
Hi!
I've testing this weekend the HxC with my BBC Micro.
I've converted SSD images to HFE format with the latest software, and all I can get to work, is to show "only once" the contents of the disk.
I mean, I switch both BBC and HxC, then mount an image, and in the computer type:
*CAT
(It shows the content of the disk)
Then, ANYTHING done after this first command, results in an error.
Turning OFF and ON again, the same result.
The jumpers are configured with only one drive, like an amiga configuration...
Any help?
Re: BBC Micro support (issues).
As always :
Hardware version ?
Firmware version ?
Software version ?
Exact jumper position ?
Floppy cable used ?
And if possible the file image (source + HFE)
javidoom
Post by javidoom »
Hi!
Sorry, let me fulfill data:
Hardware version ? HxC Rev. B (with patch to support amiga write). (When it starts the screen indicates Rev C)
Firmware version ? Latest, 1.6.0.0
Software version ? Latest 1.6.11.15
As only one drive in Amiga setup. (ID0 drive A) Only ONE jumper in this position.
Floppy cable used ? Standar NOT TWISTED.
And if possible the file image (source + HFE): I've uploaded them to Fileserve:
http://www.fileserve.com/file/bSkmt3J/HxCBBCMicro.rar
There is the image disk: .SSD
the CFG used in the SD, and
the .HFE used.
Many thanks!
(I'll check firmware version later in home :) ): Checked. 1.6.0.0
Can you send me the files images by email ?
javidoom
Post by javidoom »
Hi!
Sure! Please send me your email address.
Regards.
javidoom wrote:Hi!
Regards.
You can get this email everywhere (software, website...) : https://hxc2001.com/contactus/
javidoom
Re: BBC Micro support (WORKING).
Post by javidoom »
Hi!
Thanks Jeff!!
I have now it working perfectly! :)
Here is the Video running some games:
http://imageshack.us/clip/my-videos/190/file22218.mp4/
Regards.
