Peavey DPM
rcw13
Peavey DPM
Post by rcw13 »
Does anyone know if the SD card floppy emulator will work with the Peavey DPM series of synthesizers? The original (now inoperable) floppy drive in my Peavey DPM 3SE is a stock Sony DD drive. The floppies are in MS-DOS format. So it sounds like the emulator WOULD work, but I was hoping for confirmation.
Re: Peavey DPM
rcw13 wrote:Hello,
No confirmation for the moment but as you guest this should work without problem.
Of course if you got any problem, contact us !
