Old HxcFloppy in CPC6128
DFL
Post by DFL »
Hi, some years ago I build my own SD HxC and I´m still using it in Amiga 500. Today I was trying to hook up in a CPC 6128 internal but CPC can´t find the drive. My cable was built according to this guy http://www.cpcwiki.eu/index.php/HxC_SDCard_Internal
Is there a way to the old HXC works in the CPC? What´s the jumper position?
Re: Old HxcFloppy in CPC6128
DFL wrote:Hi, some years ago I build my own SD HxC and I´m still using it in Amiga 500. Today I was trying to hook up in a CPC 6128 internal but CPC can´t find the drive. My cable was built according to this guy http://www.cpcwiki.eu/index.php/HxC_SDCard_Internal
Yes :
DFL
Post by DFL »
I check this manual, but my HxC is the old one
https://hxc2001.com/floppy_drive_emulat ... brew_1.jpg
I already tried all jumpers positions but without luck.
Anyway, thanks for the help
DFL wrote:I check this manual, but my HxC is the old one
Ok. So your problem is probably related to one of this bug :
https://hxc2001.com/floppy_drive_emulat ... _notes.txt
