Unable to save?
futureman
Unable to save?
Post by futureman »
I finally got around to trying to save Some samples on my EII..
I used a disk image that already had something on it (piano)
All seemed to be working fine.. And it went through the whole 'saving' procedure..
Unfortunately, when I then loaded up the disk, it still had the same piano sample on it..
(my samples were gone)
On an EII, saving onto a disk erases everything on the disk and replaces it with the EII's memory.
I've updated my HxC to the latest OS.
I checked the write protect on the SD card, but that made no difference.
Could there be something I'm missing?
Kind regards
Mike.
Re: Unable to save?
Board revision ?
futureman
Re: Unable to save?
Post by futureman »
REV C board.
(100910)
futureman
Re: Unable to save?
Post by futureman »
Hmmmmm.
When I try and update the bootloader, I get..
I'm using the HxC_SD_Bootloader_V1_0TOV1_1.upd file taken from the website.
What could cause this error?
If i go ahead and update the firmware, I then get
I feel like I'm missing something, but not sure what.. it should be simple eh?
Re: Unable to save?
Firmware version on the HxC ?
futureman
Re: Unable to save?
Post by futureman »
Firmware is 1.6.0.0
I've had a breakthrough.
I tried another 'blank' disk that a friend had made and verified on his E2 with HxC, and it worked.
When writing on his disk the display was slightly different as opposed to my disks.. I'll film it and upload to YouTube for reference.
I'm not sure why writing over his blank worked, while mine didn't..
At first I thought it may have to do with the file name but changing that didn't change the outcome.
Cheers
Mike
Re: Unable to save?
futureman wrote: I'm not sure why writing over his blank worked, while mine didn't..
Cheers
Mike
Maybe because you use a very old software to generate them ?
Some know working images :
