yamaha sy99 fonctione avec emulateur???
artico78
Post by artico78 »
je voudrer chercher de decouvrire si quelquin as deja essaier, mercie pour votre reponces
Re: yamaha sy99 fonctione avec emulateur???
artico78 wrote:je voudrer chercher de decouvrire si quelquin as deja essaier, mercie pour votre reponces
Yes it does, but you need the 34pins-> 26pins converter.
DrSynth
Post by DrSynth »
Help please,
What are correct jumper settings for Gotek SFRM72-TU100K drive after flashing with with current HxC 3.9.8.2a firmware? Using with Yamaha SY99 keyboard
I have the 34 pin -> 26 pin converter, which worked correctly with this Gotek drive and the original Gotek firmware with one jumper set on the S1 pin. But file manger is WIndows only and I get tired of having to run VMWare Fusion to manage disk images. So everyone recommends HxC firmware, I decided to try it
After flashing and loading the firmware, the display on the drive is able to scroll through the 100 hfe images, but when I try to access any of them, I get "Disk not ready" error
Thanks in advance,
Manny
Which HFE ?
DrSynth
Post by DrSynth »
Searching around the WWW for a while today I found a posting showing only one jumper on the M0 pin is needed.
All is working well now.
Thanks !
