MSX1 and HxC
Turrican
MSX1 and HxC
Post by Turrican »
Hello all!
I have a MSX 1 and an IDE interface for it.
I bought the HxC2001 and I´m trying to make it work with no success...
I have the 5 1/4" disk drive and it works with my IDE interface. So, how can I make HxC to work with my MSX?
MSX has a standard IDE interface (34 pins) and uses DSK images.
The File Converter has the MSX2 option to convert DSK images.
Can I use this option (MSX2) to export my images?
I used it but the MSX didin´t reconize the images (or the disk).
I think the MSX 1 uses the standard Shugart/IBM-PC disk drives.
With the 5 1/4" disk drive I use a non-cross flat-cable.
Thanks!!!
mau_rizio
Re: MSX1 and HxC
Post by mau_rizio »
Hi Turrican,
what msx model and what ide? You say 5 1/4" disk so you have a spectravideo?
I've tested the hxc on a vg8020 with vy-010 disk interface without any problem.
An yes, for exporting you have to use MSX2 option.
bye
mau
Turrican
Re: MSX1 and HxC
Post by Turrican »
Hi mau_rizio.
I have a Brazilian MSX (the Expert 1.0).
I´m from Brazil. :)
My IDE interface is a DDX (made in Brazil). A cartridge interface.
It works on both 5 1/4 and 3 1/2 disk drives and I have an external 5 1/4 disk drive.
I´ll test with different jumper settings.
Turrican
Re: MSX1 and HxC
Post by Turrican »
Didn't work! :(
Normal cable, twisted-cable, changing the jumper setting, using Amiga, IBM-PC 720K, MSX2 settings. :(
And with the 5 1/4"disk drive, it works. :(
Re: MSX1 and HxC
Turrican wrote:Didn't work! :(
Ok but what about the disk image you are using ? can you send me it ?
Turrican
Re: MSX1 and HxC
Post by Turrican »
Hi Jeff!
An email was sent with 2 disk images.
Turrican
Re: MSX1 and HxC
Post by Turrican »
SOLVED!!!!!!!!!!!
8)
Brazilian MSX 1 works great with HxC!
Thanks to Jeff!!!
Re: MSX1 and HxC
The "solution" :
The Floppy access led should be on only when the MSX try to read it...
Reverse the floppy cable and tell me how react the leds !!
----- Original Message -----
To: hxc2001
Sent: Monday, January 23, 2012 11:33 PM
Subject: RE: MSX 1 disk image
Yes, all the leds are always on.
How the leds should stay? :)
To: al_colella
Subject: Re: MSX 1 disk image
Date: Mon, 23 Jan 2012 23:28:48 +0100
>Well, when I load the file in HxC, the 3 lights stay on (red, yellow and green).
So all led is always on ?
In this case try to reverse the floppy cable on the HxC side OR on the MSX side.
To: hxc2001
Sent: Monday, January 23, 2012 11:23 PM
When the MSX try to access the emulator, nothing happens...
To: al_colella
Date: Mon, 23 Jan 2012 23:15:32 +0100
no particular problem with these images.
have you tried the ID0-Drive A jumper setting ?
How react the floppy emulator access LED when the msx try to access it ?
