VFD for the SD HxC Floppy Emulator !
I have added the HFE support to the Virtual Floppy Drive driver (VFD) :
VFD with HFE files support :
https://hxc2001.com/download/floppy_driv ... fd_hxc.zip
Original software:
http://vfd.sourceforge.net/
This software allows you to open directly HFE files with a FAT/DOS file system under windows like a normal floppy disk drive !
How to install VFD for the SD HxC Floppy Emulator (*.hfe support) ?
-> Start vfdwin.exe
-> Driver -> Browse -> Select the file vfd.sys present in the driver folder. -> Intall -> Start
-> Association -> Check .hfe -> Apply.
The driver is now ready.
To open an HFE file, you have just to double click on it.
Note : Any change are writing back to the hfe file when the disk is unmounted.
To do this vfdwin.exe -> Drive 0 -> Close
OR
Reopen the same hfe file.
Jeff/HxC2001
12/08/2011
Dav
Re: VFD for the SD HxC Floppy Emulator !
Post by Dav »
i've just tested it with amiga HFE files (2001 Ko) and it doesn't work : " ... the image is too small". :?
Any ideas ? :)
pulkomandy
Post by pulkomandy »
Dav wrote:Hello,
Any ideas ? :)
Yes VFD is only for MSDOS / PC / FAT (atari st...) type floppy image.
Since ADFOpus is open, i will probably add the library to it ;)
New version :
Some bugs corrected, x64 support.
New version again :
More bugs corrected.
This is now ok for a public release ;)
audric
Post by audric »
Willing to pay a reasonable amount to have a signed version of vfd_x64.sys
thanks
