Switching between internal Floppy and HxC
futureman
Post by futureman »
Is there an easy way to implement swapping between HxC and internal Floppy drive on an Emulator 1?
Ideally I'd want to do this while the power is on.
I realize I could switch it with one of those big massive printer port type switches (or two) but I was wondering if there is a more elegant and simple solution such as changing the devices ID etc?
As always, thanks for your help.
Mike
Re: Switching between internal Floppy and HxC
futureman wrote:Is there an easy way to implement swapping between HxC and internal Floppy drive on an Emulator 1?
Mike
Just use a switch to exchange DS0 <-> DS1.
That's all ;)
futureman
Post by futureman »
Hey there, could you please elaborate, I'm a little confused by what you are saying..
Do you mean swap the ID of both drives (HxC and E1's internal drive)?
ie, make HXC DS0 and E1's DS1, then swap to make HxC DS1 and E1's DS0 ?
Kind regards
Mike
futureman wrote:Hey there, could you please elaborate, I'm a little confused by what you are saying..
Kind regards
Mike
This is a switch ;)
V
.................../ ---- HXC DS0
HOST DS0 ----/
.............../ ---- FLOPPY DRIVE DS0
http://rocky.digikey.com/weblib/ITT%20C ... 1SDCQE.jpg
futureman
Post by futureman »
Ahhhhh.
Got it.
Cheers
Mike
futureman wrote:Ahhhhh.
Got it.
Cheers
Mike
if you want exchange drive 0 & drive 1 use a double switch :
http://rocky.digikey.com/weblib/ITT%20C ... J1ZQE2.jpg
futureman
Post by futureman »
Ordered HxC for my E1.
Will post pics of how I go.
Cheers.
Mike
jbfairlight
Post by jbfairlight »
Jeff you write "Just use a switch to exchange DS0 <-> DS1."
yes... but when I switch the HxC in DS1 position, like that (jumper : # red) :
3 2 1 0
x x x x Drive B
x x # x
x x # x Drive A
The Emulator II is able to read disk images but unable to write or format the same disk image :?
jbfairlight wrote:Jeff you write "Just use a switch to exchange DS0 <-> DS1."
3 2 1 0
x x x x Drive B
x x # x
x x # x Drive A
Any error message ?
And at the DS0/ID0 position ? Are you able to write ?
jbfairlight
Sur l'Emulator II :
Disk [1-8]
DiskFormat Error
Et sur le HxC :
OS_3.1.hfe
S:000/080 S:0
Et oui si le HxC est ID0 ca fonctionne parfaitement et donc fonctionne pour la copie des sons et des formats speciaux du HxC vers lecteur de disquettes.
Mais il faut absolument qu'il soit en ID1 (second) pour permettre la copie des boot secteurs particulier de certaines disquettes.
Comme les disquettes : Test mémoire, Test scanner, Test sons, et même copie de version d'OS...
Car le logiciel de l'Emulator ne copie bas niveau (fonction 8 [8-FORMAT DISK] se qui implique un formatage suivi de la copie du boot strap) que du lecteur I vers le lecteur 2.
Alors que pour les sons il est possible de les charger sur le 1 et le 2 et des les sauver sur le 1 ou 2 :)
jbfairlight wrote:Sur l'Emulator II :
Disk [1-8]
DiskFormat Error
Et sur le HxC :
OS_3.1.hfe
S:000/080 S:0
Oui Et quand le HxC est en drive 0 ça marche ou pas ?
jbfairlight
oui regarde ma réponse au dessus
alors que ca fonctionne tres bien en faisant :
A) chargement d'un son a partir du lecteur 0 dans l'emulator
B) sauvegarde d'un son de l'emulator vers le lecteur 1
:roll:
jbfairlight wrote:oui regarde ma réponse au dessus
:roll:
Il est ou le HxC ?
C'est une version boitier que vous avez ?
jbfairlight
comment ca ?
jbfairlight wrote:comment ca ?
:roll:
Je ne comprend pas : Il y a un HxC dans ce cas ?
