What is HFE2 format?
kitahei88
Post by kitahei88 »
Hello ,Jeff.
I have one question .
what is HFE2 format?
what is the difference from HFE format?
what point is improved ?
do you have any information like this document ?
https://hxc2001.com/floppy_drive_emulat ... format.pdf
I'm using HxC and HFE images under old Japanese PCs (like PC-88 , PC-98 and X68k)
In that situation , do you recommend that I use HFE2 format ?
thanks .
Re: What is HFE2 format?
kitahei88 wrote:Hello ,Jeff.
thanks .
This format still in devellopment. i don't recommend to use it for the moment.
the improved point will be :
-> Flakey bits data support (for protected games)
-> Variable bitrate support (i have to check if i can do this with the actual hardware)
-> index timing included.
kitahei88
Post by kitahei88 »
thank you for replying.
do you make new dumping tool for hfe2 ? ( to dump flakey bits and any protections ?)
or only export IPF/Caps images to hfe2 ?
kitahei88 wrote: do you make new dumping tool for hfe2 ? ( to dump flakey bits and any protections ?)
No, this is not very reliable on PC...
