EFE files
Wireman
EFE files
Post by Wireman »
After recently fitting a HXC to my ensoniq EPS classic I found a download source for sounds they are in EFE format. Can they be converted for use with the HXC fitted to the Eps.
Re: EFE files
Wireman wrote:After recently fitting a HXC to my ensoniq EPS classic I found a download source for sounds they are in EFE format. Can they be converted for use with the HXC fitted to the Eps.
Yes it should.
Re: EFE files
Yes it should.
New tool to convert EFE files :
Ensoniq_EFE2HFE :
https://hxc2001.com/download/floppy_driv ... FE2HFE.zip
teevee
Re: EFE files
Post by teevee »
Jeff wrote: Thu Jul 18, 2013 10:15 am
Yes it should.
Ensoniq_EFE2HFE :
do you also have one for .EFA and EPSI?
Re: EFE files
teevee wrote: Sat May 11, 2019 11:40 am
Yes it should.
Ensoniq_EFE2HFE :
what is .EFA and EPSI?
teevee
Re: EFE files
Post by teevee »
Jeff wrote: Sat May 11, 2019 3:50 pm
Ensoniq_EFE2HFE :
EFA is a Giebler format (like EFE and EDA)
"EPSi -file type for raw image of EPS floppy,"
Re: EFE files
teevee wrote: Sun May 12, 2019 9:05 am "EPSi -file type for raw image of EPS floppy,"
If this is a classic raw file then you use the hxc software to load it (load raw file function)
efa seems to be supported by epsdisk. So you have just to change *.efe to *.efa in the "convert_efe_to_hfe.bat" script file.
