Problem creating working .EII sound bank files.
Egg
Post by Egg »
Can you tell me the exact procedure to merge the E2 OS file with the .EII sound bank files?
I took a single .EII file and converted it to .hfe using the default settings.
I then took the 3.1 OS file from the EXMP website and also converted it to .hfe.
I then put both files in one folder and put it on the SD card.
But the E2 will only load up the OS separately, it wont load the sound bank.
Re: Problem creating working .EII sound bank files.
Egg wrote:Can you tell me the exact procedure to merge the E2 OS file with the .EII sound bank files?
Just rename your OS file image to emuiios.emuiifd, put it in your *.EII folder, and convert them with the HxC software.
emuiios.emuiifd and *.EII file will be merged together.
Egg
Post by Egg »
Thanks Jeff, I have just done exactly that and it has made two files; emuiios_emuiifd.hfe and the sound bank .hfe. I guess I expected to see one file if it was merging the two together.
Anyway I will test it on the E2 when I get home in a little while.
if you have done a "batch convert" this only a side effect. just use the hfe sound bank.
Egg
Post by Egg »
Ok tested.
It works but with an initial error:
Switch E2 on, it displays "Insert Diskette". Choose file on HxC, selecting soundbank.hfe. E2 doesn't load file, it just displays "DiskFormat Error". Click on HxC to de-select soundbank file, click back on the same file again to re-select it, loads fine and works as normal.
Is this normal, and can it be rectified?
Egg wrote:Ok tested.
This is a know issue. I am working on this.
jbfairlight
Post by jbfairlight »
Hi Francois, do you find corrections for this bug ?
I like fix this :wink:
jbfairlight wrote:Hi Francois, do you find corrections for this bug ?
Sans la machine difficile de corriger cela...
