Own floppy manager?
NBG
Own floppy manager?
Post by NBG »
is it hard to code an own floppy manager software which appears on boot?
I would like to select games with their screenshots/thumbnails for example...
Or contains your floppy software hidden/secret stuff?
NBG
pulkomandy
Re: Own floppy manager?
Post by pulkomandy »
The software is open source and the protocol is documented. So it's not too hard to modify it :)
elpiloto
Post by elpiloto »
where is the open source of the program for Amiga?
cheers
elpiloto wrote:where is the open source of the program for Amiga?
cheers
On the sourceforge project page.
elpiloto
Post by elpiloto »
I meant the source of the emulator manager for amiga
elpiloto wrote:I meant the source of the emulator manager for amiga
Yes. So this is on the sourceforge project page. do you know SVN ?
elpiloto
Post by elpiloto »
yes, i see 4 files, 2 dlls, and two exes, HxCFloppyEmulator.exe and hxcfe.exe, both are the pc side
cheers
elpiloto wrote:yes, i see 4 files, 2 dlls, and two exes, HxCFloppyEmulator.exe and hxcfe.exe, both are the pc side
cheers
? So :
Follow "HxC_Floppy_Emulator_software source code: http://sourceforge.net/projects/hxcfloppyemu/"
Then http://hxcfloppyemu.svn.sourceforge.net ... floppyemu/
http://hxcfloppyemu.svn.sourceforge.net ... _selector/
And finally : http://hxcfloppyemu.svn.sourceforge.net ... tor_Amiga/
Just use subversion to get all of this correctly:
<<Subversion Access
This project's SourceForge.net Subversion repository can be checked out through SVN with the following instruction set:
svn co https://hxcfloppyemu.svn.sourceforge.ne ... cfloppyemu hxcfloppyemu
Warning
This is a generic Subversion checkout command which will pull all modules, tags and/or branches of the project. Please refer to project home page for specific SVN instructions, or use "Browse Repository" link; in most cases, you will want to add '/trunk' to the HTTPS URL above to check out only trunk (main development line).
Information about accessing this Subversion repository may be found in our document titled "Subversion (Version Control for Source Code)".
Updates from within the module's directory do not need the URL string.
NOTE
UNIX file and directory names are case sensitive.
elpiloto
Post by elpiloto »
thank you jeff! :D
cheers
