Converting GHK files using import raw image
cixelsyd
Post by cixelsyd »
G'Day and thanks for a great product.
I've managed to install my HxC. I've got the jumper set to ID0 A and I have successfully converted a blank EDE disk image to my SD card. I'm able to write to the disk on the sd with no problems.
I have some disk images that end in GHK. I believe these are created by Ensoniq Disk Tools and are an image of the EPS 16 plus disk.
I have tried importing them using the raw file import.
disk type: MFM
GAP3: 40
Sectors 80/9/0
I've used various settings in trying to convert these files but nothing seems to work. Can someone in the forum with an EPS 16 plus please confirm the settings for converting these files?
Thanks again for a great product.
Sorry, the error that I get from the EPS 16 plus when trying to access these disks (on the SD card) is Bad Device ID
I hope this helps
Re: Converting GHK files using import raw image
cixelsyd wrote:G'Day and thanks for a great product.
disk type: MFM
GAP3: 40
Sectors 80/9/0
I hope this helps
Send me some files images : https://hxc2001.com/contactus/
cixelsyd
Post by cixelsyd »
thanks for the quick response.
Just sent them.
cixelsyd wrote:thanks for the quick response.
Just sent them.
New format support -> New software !
waiting for your tests results.
cixelsyd
Post by cixelsyd »
Just sent them.
WOW! nice job. I'll test it today and post the result.
cixelsyd
Post by cixelsyd »
I just gave it a go with exactly the same settings as my original post and its still coming up with "Bad Device ID" on the Ensoniq.
any advice would be appreciated.
Regards
cixelsyd
cixelsyd wrote:Hi Jeff,
Regards
cixelsyd
There are no setting to set :
Just drag&drop the GHK file on the main window and just do an export.
GHK files are now directly supported.
cixelsyd
Post by cixelsyd »
Like I said, I'm still getting an error. The EPS 16 plus comes up with Bad Device ID when I try and access these converted files.
Regards
James
Regards
James
New version (v1.6.11.12a):
cixelsyd
Post by cixelsyd »
Regards
James
thanks Jeff,
I'll give it a go later on today on my return from work.
cixelsyd
Post by cixelsyd »
still no good. I'm getting the same "Bad Device ID" from the Ensoniq.
Let me know if you want copies of the files.
Regards
James
cixelsyd
Post by cixelsyd »
Just to clarify, in your last post you state the version as 1.6.11.12a
the version I downloaded from your provided link is labelled 1.6.11.13. Does this have any impact?
No not on the GHK support..
Regards
James
Yes send me the HFE+GHK file.
cixelsyd
Post by cixelsyd »
Regards
James
Done
