Software upgrade
tdziGer
Software upgrade
Post by tdziGer »
Hallo, Jeff. I have some problems with transferring data from PC to SD HxC Floppy Emulator.
I use SD HxC Floppy Emulator for CNC of embroidering machine. This machine has its own file format which is not visible in the operating systems newer than Windows 98. Special embroidery design program can coppy these files to a floppy disk but it is the problem.
Is it possible to add in your software emulation of real floppy drive? It will make work with your device more comfortable.
Re: Software upgrade
tdziGer wrote:Hallo, Jeff. I have some problems with transferring data from PC to SD HxC Floppy Emulator.
Under which OS is working your software ?
tdziGer
Post by tdziGer »
Under Windows XP. Type of Floppy Disk is 3.5" 720Kb 2DD.
tdziGer
Post by tdziGer »
Jeff? Have you some problems with it? If you do this then I want to buy 40 processors with your firmware.
tdziGer wrote:Jeff? Have you some problems with it? If you do this then I want to buy 40 processors with your firmware.
This may help :
http://www.petri.co.il/virtual-floppy-disks-vmware.htm
and
http://www.petri.co.il/virtual_mount_vm ... vmware.htm
Can you send me your software ?
tdziGer
Post by tdziGer »
Yes, I have used this emulator. Just a bit uncomfortable. First you need to make the disk image. Then convert it to a format .hfe. It's a bit difficult for the average user. A little later I will give a link to the program and a couple of files for experiment.
tdziGer
Post by tdziGer »
tdziGer
Post by tdziGer »
Hallo, Jeff. Have you an interest to make this work or some problems with it?
tdziGer wrote:Hallo, Jeff. Have you an interest to make this work or some problems with it?
Why don't you use another Floppy emulator on the PC to use directly the software with the HxC ?
tdziGer
Post by tdziGer »
Could you explain what do you mean?
tdziGer wrote:Could you explain what do you mean?
Plug an SD HxC Floppy Emulator on the PC that you are using with the software.
Your software will write on one image on SDCard (as a normal floppy). After this you have just to get the HFE file and duplicate it if needed on other SDCard for your machines.
tdziGer
Post by tdziGer »
If I use a laptop that has not a port for a floppy drive.
tdziGer wrote:If I use a laptop that has not a port for a floppy drive.
Ok i see. And what about an modified USB floppy disk drive with the HxC inside ?
tdziGer
Post by tdziGer »
That sounds good, if the USB floppy drives for the laptop it is not uncommon.
