Special floppy emulator
tdziGer
Post by tdziGer »
Hallo. I need some special floppy emulator for embroidery machine. Old type of floppy drive is 3,5" TEAC FD-235F, 720KB, 2DD, PC compatible (link: http://www.teac.com/data_storage/floppy ... py_drives/). SD Floppy Emulator fit to me. Following format is used: IBM system 34 format.
Could you upgrade software and firmware leave only parameters for this data type. If you need some more information ask me. With best regards, Serhii.
Re: Special floppy emulator
tdziGer wrote:Hallo. I need some special floppy emulator for embroidery machine. Old type of floppy drive is 3,5" TEAC FD-235F, 720KB, 2DD, PC compatible (link: http://www.teac.com/data_storage/floppy ... py_drives/). SD Floppy Emulator fit to me. Following format is used: IBM system 34 format.
This should already works without problem with the HxC Floppy Emulator.
Why do you want to modify the firmware ?
tdziGer
Post by tdziGer »
1. It will be easier for people who work on the equipment
2. Cheaper for production? (cheaper processor).
P.S. more information in the letter redirected from Lotharek.
tdziGer wrote: 1. It will be easier for people who work on the equipment
This is not a firmware problem but a software problem.
You can easily make some batch script to easily convert/copy floppy images.
tdziGer wrote: 2. Cheaper for production? (cheaper processor).
cheaper processor?
Unfortunately you will gain almost nothing for lot of works... Max gain expected : 0.88$
tdziGer
Post by tdziGer »
Thanks for reply, Jeff. May be after the test device, I receive more concrete suggestions. Thank you for your attention. Best wishes.
