Amiga 1000
gilles
Amiga 1000
Post by gilles »
Not a question here, just a success story :)
RevC of SDCard HxC runs out of the box on amiga 1000 (PAL).
Tested with kickstart 1.1(PAL) from TOSEC.
Re: Amiga 1000
gilles wrote:Not a question here, just a success story :)
Thanks for the feedback :)
noice
Re: Amiga 1000
Post by noice »
I ordered a SD HxC today and am searching for experience on the Amiga 1000.
How do you convert a .rom-image of the Kickstart disk into something the HxC understands? Is there a way to tell the HxC to boot one file on startup (kickstart) before going into normal operation mode (ie boot last image, but not the kickstart)?
Regards
Re: Amiga 1000
noice wrote:I ordered a SD HxC today and am searching for experience on the Amiga 1000.
Regards
It's an ADF file ? if yes just convert it to HFE, rename it to STARTUPA.HFE and activate "Force loading STARTUPA.HFE into the driv A at power up" option.
noice
Re: Amiga 1000
Post by noice »
Jeff,
thank you for your reply. I reckon that this is printed in the manual so I was asking for information I could have retrieved on my own. No good start in a forum. Sorry for that.
I was playing around with the HxCFloppyEmulator (glad it works with wine!). The kickstart rom is not in ADF format and as my Amiga floppy drive is near dead, creating a DMS or ADF file of my kickstart disks is just a last ressort. I want to convert the .rom-Files to HFE. I guess I have to try the RAW file format conversion in HxCFloppyEmulator and check if that works when the HxC arrives.
Edit: thinking about the whole thing again, I most probably will have to create the image from disk (.rom being just what it is: a rom image, no disk image)
pulkomandy
Re: Amiga 1000
Post by pulkomandy »
You don't need wine, there is a command-line version of the software for others OS :)
Re: Amiga 1000
noice wrote: Edit: thinking about the whole thing again, I most probably will have to create the image from disk (.rom being just what it is: a rom image, no disk image)
Yes i think too ;) Maybe an adf can be found somewhere ?
EDIT : in fact i have these kickstart adf...
noice
Re: Amiga 1000
Post by noice »
pulkomandy wrote:You don't need wine, there is a command-line version of the software for others OS :)
Thanks for pointing THAT out, works great. Sometimes command line versions are so much more convenient ;)
3 evenings later, my trusty Amiga1000 (+Mouse, Keyboard, 1081) is clean and working now, waiting for the HxC. I found all the original pieces but the expansion port cover. This was my only computer from 1986 to 1993. Helped a lot in skipping the whole DOS and Windows crap, jumping right into Linux in 1993, making a living of it now. Thank you so much, Amiga! :D
SinCity
Re: Amiga 1000
Post by SinCity »
Help needed. I am waiting for my USB floppy emulator and I have an Amiga 1000. How do I convert a 1.3 Kickstart ROM file into a ADF?
Re: Amiga 1000
SinCity wrote:Help needed. I am waiting for my USB floppy emulator and I have an Amiga 1000. How do I convert a 1.3 Kickstart ROM file into a ADF?
Here the needed ADF file :
http://www.lemonamiga.com/help/kickstar ... om-1-1.php
The following Kickstart v1.1 images are available in TOSEC:
- Kickstart-Disk v1.1 rev 31.34 (1985)(Commodore)(A1000)(NTSC).adf
- Kickstart-Disk v1.1 rev 32.34 (1986)(Commodore)(A1000)(PAL).adf
- Kickstart-Disk v1.1 rev 32.34 (1986)(Commodore)(A1000)(PAL)[a].adf
SinCity
Re: Amiga 1000
Post by SinCity »
Starting a new thread
