Version 1.6.8.1
endre1952
Version 1.6.8.1
Post by endre1952 »
"Variable bitrate supported" - does it apply to the SD-card version now?
Re: Version 1.6.8.1
endre1952 wrote:"Variable bitrate supported" - does it apply to the SD-card version now?
Soon ;)
saeid62
Re: Version 1.6.8.1
Post by saeid62 »
hi,
Recently a HxC Floppy Drive Emulator with version 0.2.2.0 of Germany by one of my friends.
But i can't updated with the version 1.6.8.1 .
-> Copy the new bootloader file (HxC_SD_Bootloader_V1_0TOV1_1.upd) to a freshly formated FAT32 SDCard.
-> Press Left and Right buttons before power up and keep it pressed at least 1 seconds at power up.
-> Wait some seconds. When 2 leds are blinking (Sdcard access led and Floppy Access led) it's done !
(to be sure wait 1 minutes before removing the power supply).
but..........
help Please.
thanks
Re: Version 1.6.8.1
saeid62 wrote:hi,
No you cannot. v0.2.2.0 and older versions are incompatible with the actual hardware.
saeid62
Re: Version 1.6.8.1
Post by saeid62 »
hi jeff;
thank you reply.
what is supports version for this hardware?
Can you give it to me?
thanks
lotharek
Re: Version 1.6.8.1
Post by lotharek »
You have pre-production version probably. No upgrade possible. If Your SD emul doesn`t look like those I sell - sorry. Can`t do about that nothing.
ps. As far i remeber we have started form firmware 1.0.. Jeff ???
..... Atari Roxxx !!!
