Speccy Power
Beaps
Speccy Power
Post by Beaps »
Hi All,
My +3 has just arrived and I noticed the power supply for the internal drive has red, black, black, orange.
What do I have to do snip the orange wire so it doesnt blow up my HxC?
Re: Speccy Power
Beaps wrote:Hi All,
mhh nothing ? this is standard power supply connector ?
Beaps
Re: Speccy Power
Post by Beaps »
yer its standard.
pulkomandy
Re: Speccy Power
Post by pulkomandy »
It may be the same as in the Amstrad CPC, Orange being +5v and Red being +12. But I'm not sure... Be careful with it.
Beaps
Re: Speccy Power
Post by Beaps »
I reckon so as the motherboard say AMSTRAD (as they bought out Spectrum)
Ok so I should attach the other way around?
Re: Speccy Power
Beaps wrote:I reckon so as the motherboard say AMSTRAD (as they bought out Spectrum)
Before pluging anything check the voltage ...
The power supply pinout is in the user manual :
johndaviesbmi
Re: Speccy Power
Post by johndaviesbmi »
Keep the Orange wire, Its the red wire that you need to disconnect
