adf files.
Beaps
adf files.
Post by Beaps »
Why is it that adf files work sweet on winuae & not hxC?
What I mean is when they are loaded in HxC after a few seconds loading they say "insert disk in dfo" "suspend or quit" messgage appears, on Winuae they work no problem?
Re: adf files.
Beaps wrote:Why is it that adf files work sweet on winuae & not hxC?
Which ADF exactly ?
Beaps
Re: adf files.
Post by Beaps »
quite a few to be honest - head over heels, ik+, chaos engine 1, james pond robocod etc
Re: adf files.
Beaps wrote:quite a few to be honest - head over heels, ik+, chaos engine 1, james pond robocod etc
Which jumper setting are you using ? On which Amiga?
Beaps
Re: adf files.
Post by Beaps »
tried em both ways with df1 & without df1
Re: adf files.
Beaps wrote:tried em both ways with df1 & without df1
On which Amiga?
Please make a complete description of your setup:
-> USB or SDCard Floppy Emulator ? Which revision ?
-> Jumper setting : One or two jumper ? Position ?
-> Floppy cable used : Twisted or not ?
-> Firmware version ?
-> Software version ?
-> Amiga Used (Amiga Model + RAM size)
Beaps
Re: adf files.
Post by Beaps »
-> USB or SDCard Floppy Emulator ? Which revision ? SDCard
-> Jumper setting : One or two jumper ? Position ?Tried both
-> Floppy cable used : Twisted or not ?Original Amiga
-> Firmware version ?Latest
-> Software version ?Latest
-> Amiga Used (Amiga Model + RAM size)Standard Amiga 600
Re: adf files.
Beaps wrote: -> Jumper setting : One or two jumper ? Position ?Tried both
Both what ?
Beaps
Re: adf files.
Post by Beaps »
jumper on DF1
jumper off DF1
both settings
Re: adf files.
Beaps wrote:jumper on DF1
jumper off DF1
both settings
Yes but at which position did you put the jumper(s) ?
NBG
Re: adf files.
Post by NBG »
Beaps wrote:-> Amiga Used (Amiga Model + RAM size)Standard Amiga 600
That's the "problem". Some old games don't run on A600.
Beaps
Re: adf files.
Post by Beaps »
You know - I never thought of that, course it is.... lol
