Request of support of new formats - FDI & UDI
Alex_NEMO
Post by Alex_NEMO »
Hi, Jeff!
Whether probably to add about the near future support of following formats of images for ZX-Spectrum? These formats became the standard "de facto" in a number of emulators ZX-Spectrum and allow to "reproduce" very precisely structure of disks, including and variety of protection. On hearings, format FDI is very similar on TD0, probably, its support will make easily (simply). UDI - more difficult format, but I hope that thanks to your knowledge and experience to make its support will not constitute the big work!
Here, one of images of the protected game in format UDI:
http://zx.pk.ru/attachment.php?attachme ... 1200791114
The complete information on a FDI-format (RUS lang. - sorry...): http://www.zxdocs.fatal.ru/formats/form ... &type=html
The complete information on a UDI-format (RUS lang. - sorry...): http://www.zxdocs.fatal.ru/formats/form ... &type=html
JF, your emulator - the best :!:
Re: Request of support of new formats - FDI & UDI
Alex_NEMO wrote:Hi, Jeff!
ok i will have a look to this.
Alex_NEMO
Post by Alex_NEMO »
Jeff, thanks!
I and my friends we test it as soon as possible and I will inform at once on results.
Good luck!
Alex_NEMO
Post by Alex_NEMO »
Hi, Jeff!
We tested support of format FDI by software HxCFloppyEmulator (the last beta version v1.6.6.0a). Everything, except formatting function in "pure" TR-DOS, works correctly. All is normally read and running(started), including some protected disks. A problem with command FORMAT in early and original versions TR-DOS (© 1986 Techology Research Ltd., versions 5.03, 5,04 and some other), unfortunately, and remains. At formatting from these versions TR-DOS the image for some reason is considered as one-sided (SS) though at directory reading (LIST, CAT) and at start of programs no problems arise, the disk is considered double-side (DS). And we have 1264/1264 sectors (SS), instead of expected 2544/2544 of sectors. If to use later versions TR-DOS where the formatting subroutine is changed, or other (indirect/foreign) programs of formatting - all is normal. We receive 2544/2544 sectors and what or problems with this image afterwards do not arise. Files normally register in it. Then they are correctly displayed and then, started. I.e. similar problems are watched with any images for ZX-Spectrum: TRD, SCL, FDI and TD0, if it converted from TRD-image with the console utility TRX2X, which allows convert from/in formats: UDI, TRD, SCL, FDI, TD0, FDD, hobeta.
Jean Francois, whether probably to solve this problem? Or we simply make a stipulation (remark) that emulator operation is guaranteed with the last versions TR-DOS v6.0x/v6.1x (with the corrected subroutine of formatting), or it is necessary to use outside programs for formatting.
