roland g800
mrsim822
roland g800
Post by mrsim822 »
this keyboard has a panasonic ju57A166P there is 5 or 6 jumpers in it so which settings of jumpers i will do on hxc floppy drive emulator ??
Re: roland g800
mrsim822 wrote:this keyboard has a panasonic ju57A166P there is 5 or 6 jumpers in it so which settings of jumpers i will do on hxc floppy drive emulator ??
Try the shugart mode.
mrsim822
Re: roland g800
Post by mrsim822 »
mmm what is shugart mode :( i don t know about it can u tell me plz ?
Re: roland g800
mrsim822 wrote:mmm what is shugart mode :( i don t know about it can u tell me plz ?
Do you have the emulator ?
mrsim822
Re: roland g800
Post by mrsim822 »
i don't have this emulator i have gotek but it's not working ! the keyboard mark on screen that i have to format disk ! then disk not ready .. so i want to buy hxc but i wont waste more money if it will not fonction also :S
my floppy drive is :
PANASONIC JU 257A166P JUMPERS :
1 RY
2 MO
3 D0
4 PC
so r u sure it will work ??
Re: roland g800
mrsim822 wrote:i don't have this emulator i have gotek but it's not working ! the keyboard mark on screen that i have to format disk ! then disk not ready .. so i want to buy hxc but i wont waste more money if it will not fonction also :S
1 RY
2 MO
3 D0
4 PC
Almost sure. If you cannot get it working we can refund you.
Of course if you got any problem to get it working don't hesitate to contact me.
mrsim822
Re: roland g800
Post by mrsim822 »
mmm ok i wana try ! so from where i can buy it ?
Re: roland g800
mrsim822 wrote:mmm ok i wana try ! so from where i can buy it ?
Follow the links... :
https://hxc2001.com/floppy_drive_emulat ... ALESPOINTS
mrsim822
Re: roland g800
Post by mrsim822 »
ok ! did u replace before a panasonic ju257a floppy drive ?
Re: roland g800
mrsim822 wrote:ok ! did u replace before a panasonic ju257a floppy drive ?
mhh yes why ?
mrsim822
Re: roland g800
Post by mrsim822 »
because the floppy drive of my keyboard panasonic ju257a166p
mrsim822
Re: roland g800
Post by mrsim822 »
hello jeff i saw this video is it ur team who made it ? so finaly it is working ?
http://www.youtube.com/watch?v=eaV7ZJaFgDE
Re: roland g800
mrsim822 wrote:hello jeff i saw this video is it ur team who made it ? so finaly it is working ?
Yes it works :
Pin 2 to ground (I connect pin 1 and 2) is the solution for the problem.
Now I can read from Emulator, format the image with Keyboard and also record a midi file from keyboard to Emulator.
Abstract for Roland G-800:
My keyboard has a controller HD63266F and a floppy Chinon FZ-357. Jumper on the Chinon floppy is set to DS0 and MM.
To replace floppy with Emulator you have to do these points:
1. Set the jumper to Drive A ID3
2. Reverse the floppy cable. This means that on Chinon Pin1 is on Emulator Pin 34
3. Connect Pin 1 to Pin 2 from Emulator.
Cristian Nita
Re: roland g800
Post by Cristian Nita »
Hello! My name is Cristian.I got one floppy emulator gotek sfrc922c from ebay where on description says is compatible for an electronic keyboard Roland G800. I try to fit this on my keyboard but i dont know how to connect properly the pin-s on back of the emulator. Can you help me ? The emulator is light up the usb stick flashing but the keyboard doesn't see the styles from usb. I got a CD also with some programs wich help me to format the usb in right mode.So I don't know how to make to work.If you can help me with some informations will be grate.. Thanks!!!
