Converted files
Beaps
Converted files
Post by Beaps »
Hi All,
Just batch converted some .ST games 1.8GB to .hfe and they have doubled in size (nearly 4GB). The device only supports 2GB so what am I supposed to do, cut my roms list in half?
Re: Converted files
Beaps wrote:Hi All,
Or buy an 8GB sdcard ;-)
Beaps
Re: Converted files
Post by Beaps »
I thought it only supports cards up to 2GB?
Re: Converted files
Beaps wrote:I thought it only supports cards up to 2GB?
No! Up to 32GB !
SDHC Cards are supported!
Beaps
Re: Converted files
Post by Beaps »
I cant find whether it takes micro SD in a SD caddy?
Re: Converted files
Beaps wrote:I cant find whether it takes micro SD in a SD caddy?
This should works.
