Roland MC-300 Problems
Tarkus
Post by Tarkus »
I just received my HxC and had success with loading images for the E-MU Emulator 1. Then I tried it with a Roland MC-300 Microcomposer, and it doesn't seem to work. I created a hfe file from a known good boot disk, but when running the MC-300 it seeks track 0, then track 40 and doesn't advance any further. The MC-300 uses a WD1772 in standard configuration expecting 720K disks. I tried all possible jumper configurations with no luck. The firmware was updated to 1.6.
Could you give me some ideas on what to try next?
Thanks.
Re: Roland MC-300 Problems
Tarkus wrote:I just received my HxC and had success with loading images for the E-MU Emulator 1. Then I tried it with a Roland MC-300 Microcomposer, and it doesn't seem to work. I created a hfe file from a known good boot disk, but when running the MC-300 it seeks track 0, then track 40 and doesn't advance any further. The MC-300 uses a WD1772 in standard configuration expecting 720K disks. I tried all possible jumper configurations with no luck. The firmware was updated to 1.6.
Thanks.
Send me the hfe file by email i will have a look.
After some mails exchange here the result :
Tarkus wrote: So my tests were more successful. Here is what I found:
READ
Works fine with a disk read in Shugart mode.
WRITE
Writing data to the same disk you booted from works fine now.
I was also able to copy a disk to another image. The trick is that you can't use the left/right HxC buttons to select a new image when prompted for a destination by the MR. This always seems to fail. Instead you have to press the middle button, then select the destination image and then press middle button again to select. Then it recognizes the new image and writes to it. It took four passes to copy an entire disk, and the resulting image was an exact copy of the original. **Sometimes** it doesn't recognize a new disk image after being prompted to insert destination. However, this can be overcome by pressing the middle button twice again and having the host retry. Maybe that has something to do with how the disk change line is monitored.
The two images you sent this morning behaved could both be written to.
FORMAT
This failed every time, and the error message told me that the disk I was trying to format was not formatted?!?. Kind of strange, but formatting is unnecessary since you can just copy images and rename them.
So it does work and I think that you can add the Roland MC-300 (and the electrically identical MC-500) to your list of supported devices.
-Arti
