TRS-80 Model 4
pyrate
TRS-80 Model 4
Post by pyrate »
I'm having no luck reading disks properly on my Model 4 TRS-80.
When I convert a operating system (JV3) disk to hfe, the emulator will sometimes load the operating system to a prompt. But I can't read or even list the files on the disk. As soon as I use a DIR command the system hangs. I've tried multiple different JV3 images and keep getting the same results.
Re: TRS-80 Model 4
pyrate wrote:I'm having no luck reading disks properly on my Model 4 TRS-80.
Retry with this version :
pyrate
Re: TRS-80 Model 4
Post by pyrate »
Jeff wrote: Retry with this version :
Now when I try to load the hfe image the emulator's read LED stays constantly lit, and the system hangs. It is worse than before.
Re: TRS-80 Model 4
Send me these jv3 image by email.
Re: TRS-80 Model 4
there was a bug in the JV1 format detection. This is now corrected :
https://hxc2001.com/floppy_drive_emulat ... t_beta.zip (V1.6.4.2a)
pyrate
Re: TRS-80 Model 4
Post by pyrate »
Jeff wrote:Hi,
That fixed it! Thank you very much.
