Small bug w/ autoboot file chooser
telengard
Post by telengard »
I was using the search function (F1) and it seems that 'a' and 'q' are somehow swapped. Verified my keyboard was ok in GEM.
Awesome, awesome program. Complements the device just perfect.
~telengard
Re: Small bug w/ autoboot file chooser
telengard wrote:I was using the search function (F1) and it seems that 'a' and 'q' are somehow swapped. Verified my keyboard was ok in GEM.
~telengard
Yes this is a small qwerty/azerty issue ;-)
Stay tuned because another important add-on will be available for ST : An hard disk driver for the SD HxC Floppy Emulator :-)
endre1952
Post by endre1952 »
I'm excited about the upcoming hard disk driver, I don't have a hard drive solution for the ST, expect for a 20MB old Megafile drive that I don't use. Will it work with the Rev B board? I have a Rev C unit in my Amiga 500, but a Rev B in my ST.
endre1952 wrote:I'm excited about the upcoming hard disk driver, I don't have a hard drive solution for the ST, expect for a 20MB old Megafile drive that I don't use. Will it work with the Rev B board? I have a Rev C unit in my Amiga 500, but a Rev B in my ST.
Yes this will works on Rev B.
telengard
Post by telengard »
So I fired this up again to play a game and I'm wondering if there is a setting to fix this or is there a new version of the auto boot.hfe?
telengard
Post by telengard »
telengard wrote:So I fired this up again to play a game and I'm wondering if there is a setting to fix this or is there a new version of the auto boot.hfe?
I grabbed the sources on sourceforge (many thanks for making all of this available!) and installed the cross toolchain for m68k-atari-mint-gcc, made the necessary changes and as the Makefile did, loaded the renamed output file into the HxCFloppyEmulator.exe application. It says it is an unsupported format. I tried loading it as raw and saving as an hfe but the ST doesn't recognize it.
Could someone possibly help with this final step? I'll make the binary available for download once I have it working. :)
thanks,
~telengard
thanks,
~telengard
Which output file are talking ?
telengard
Post by telengard »
thanks,
~telengard
The file that is generated by gcc is 'HXCFEMNG.PRG'. I was thinking about this last night, is it that I need to add this to a disk image (i.e. .st or .msa) and *then* convert to an .hfe?
I guess I'm just not sure what the process is after compiling the binary.
~telengard
telengard wrote:]
~telengard
Create a folder "dk.fatst" somewhere on your pc, add an AUTO folder and copy the prg file in the auto folder.
then Drag&Drop the dk.fatst folder on the hxc floppy emulator software. after this export the image.
telengard
Post by telengard »
telengard wrote:]
~telengard
Awesome, thanks. I'll try that out and report back!
~telengard
telengard
Post by telengard »
Excellent! That worked great.
I've made the file available here:
http://home.comcast.net/~bsturk/8bit/AUTOBOOT.hfe
At some point I may attempt to make this more dynamic and make a patch, really all I did was change the initializing of the keycodes based on a preprocessor def.
~telengard
