HXC SD Rev C and the Acorn Beep micro (bbc b)
lobogris
Post by lobogris »
I've read (in stardot forums: Here!) about connecting easily a standard typical pc 3.5" floppy drive to the Acorn bbc micro... So, do you know if I can use my Floppy emulator with the beep?
In affirmative case, what jumpers may I select ?
If I am not wrong, the beep uses .SSD file extensions and .IMG for discs (maybe some more...)
Many thanks in advance!
I'm very happy with the HXC, :) good work Jeff: is a cool piece of hardware! :wink:
Re: HXC SD Rev C and the Acorn Beep micro (bbc b)
lobogris wrote:I've read (in stardot forums: Here!) about connecting easily a standard typical pc 3.5" floppy drive to the Acorn bbc micro... So, do you know if I can use my Floppy emulator with the beep?
Yes you can use the HxC Floppy Emulator with this. About the jumper setting i don't know. You have to find the right setting yourself! :wink:
