Need some help, floppy LED is always on
telengard
Post by telengard »
Been wrestling with this for a few nights. I have a straight through 34 pin floppy cable (no line swap) connected to my Atari ST through a pass through connector I bought from Jameco (I bought a few different ones and they all behave the same). I have pin 1 lined up and no matter how I set jumpers etc the floppy LED stays on so I'm assuming something is not right.
Is there anything else I can try to debug this? It seems pretty straightforward as I can see the pin1 red markings and everything for the most part is keyed. I've followed all of the recommendations in the manual.
~telengard
N-Ed
Re: Need some help, floppy LED is always on
Post by N-Ed »
Maybe stupid advice, but have you tried to change the connection(turn cable 180 degrees) to the mobo?
telengard
Post by telengard »
N-Ed wrote:Maybe stupid advice, but have you tried to change the connection(turn cable 180 degrees) to the mobo?
Hi there,
I did, yes. At the only point that wasn't keyed. The Atari ST floppy connection into the pass through. The floppy LED did go off, but nothing seemed to work so I assumed it was not right. At no point did the LED go on when booting the ST.
thanks,
~telengard
Hi there,
As stated in the manual if the led is always on this probably mean that the floppy cable is reverted .
With the floppy cable in the right side (The "led off" state) change the jumper setting.
More details in the user manual:
