USB Emulator Schematic - 16 Mhz Osc. not correct?
average_male
Post by average_male »
Hello Jeff (or anybody else that can assist),
Looking at the USB schematic(1) for the USB emulator, the crystal callouts and/or connections don't look correct.
First of all, the pins are numbered 11, 14, 7, and 8, Ok so the 11 must be a typo and should be a 1, but the datasheet states that it should be disconnected, but it looks to be tied to VCC with pin 14 and the PCB picture(2) seems to show that pin 1 is disconneted. So I guess this is a drafting error on the schematic?
Can you please confirm?
Moe
Reference:
(1) - https://hxc2001.com/floppy_drive_emulat ... muCPLD.gif
(2)- In the zip file: /HxCFloppyEmulator_ipcore\PCB\USB_HxCFloppyEmulator_PCB\prod_version_revc/HxCFloppyEmulator_BOTTOM.jpg
Re: USB Emulator Schematic - 16 Mhz Osc. not correct?
average_male wrote:Hello Jeff (or anybody else that can assist),
Moe
Reference:
On the schematic you should read "11" and not "1". But a wire hide one character.
Except this, there is no problem.
average_male
that seems odd as the OSC/Crystal that you noted in the parts list doesn't seem to have a pin number 11, and that datasheets say that pin 1 should be NC (Not Connected), guess you maybe referencing a different osc/crystal.
Thanks for your response.
Part list item I was noting above:
5V 16MHZ oscillator (DIL14 or DIL8 format)
(farnell: 9510052)
average_male wrote:that seems odd as the OSC/Crystal that you noted in the parts list doesn't seem to have a pin number 11, and that datasheets say that pin 1 should be NC (Not Connected), guess you maybe referencing a different osc/crystal.
(farnell: 9510052)
No no there are no problem... This is a double footprint part on the pcb , like the sram.
the pin 11 is for small oscillator.
have a look to the pcb you will understand.
average_male
Yep, I see you have designed the PCB to work with Full and Half can packaged crystal oscillators. I guess I was expecting to see pin 1 as NC as you have noted NC on all other ICs when applicable. The combination of the two above details left room for some confusion. I am with you now.
Thanks again for addressing my quesitons in such a timely manner. You do good work.
