Converting HFE files back to Amiga ADF
megamouse
Post by megamouse »
First of all I have to say this is an amazing little device, and have thoroughly enjoyed using it.
Basically the title says it all, I need to convert the HFE files back to the Amiga ADF floppy files. Is there a program like this? Thanks for any help
Re: Converting HFE files back to Amiga ADF
megamouse wrote:First of all I have to say this is an amazing little device, and have thoroughly enjoyed using it.
Yes of course!
Open your HFE into the hxc software
Export -> choose IMG file format -> Ok
you got a file with the .IMG extension. Just change it to ADF. that's all
(you also batch convert your hfe to adf by choosing raw as target format).
megamouse
Post by megamouse »
Awesome jeff I'll try this out soon, thanks again!
