Emax SE Rack and HxC Floopy Emulator Problem
juno6
Post by juno6 »
Hi everybody...
Does anyone have the HxC SD reader/virual Floppy installed on an Emax 1?
I installed mine on my Emax SE Rack and it seems to work ok (physically), but I think I´m doing
something wrong regarding the OS or the card config.
What I did so far is:
1)Downloaded diskette images from here:
http://www.hermannseib.com/english/synt ... /banks.htm
2)Opened the HxC software and converted some .EM1 files to .HFE format into the SD memory.
(with batch convertion)
3) went to
http://emulatorarchive.com/Samplers/Ema ... maxos.html
And downloaded "emaxse11.zip", and extracted it.
4) Then I copied "emaxos.emx" into the same path (root) as the .HFE files in the SD memory stick.
I don´t have my Emax here with me right now, but it seems to read the card but then it´s
like it can´t find the OS. I tell it to load any image and it seems to be recognized by the
HxC card, but the Emax begin loading and it hangs...
What I´m doing wrong? What settings should I use on the HxC software?
Any help will be appreciated!
JZ:
Re: Emax SE Rack and HxC Floopy Emulator Problem
juno6 wrote:Hi everybody...
3) went to
JZ:
email sent with an hfe file to test.
E-smile-Z
Post by E-smile-Z »
which are the right settings for the emax?
my emax shows me the message "disk not formated"
i know i have to keep the os in the same folder..
i have the jumper on drive 0
what are the exactly drive settings for the emax?
E-smile-Z wrote:which are the right settings for the emax?
email sent.
E-smile-Z
Post by E-smile-Z »
it works now! :lol:
E-smile-Z wrote:it works now! :lol:
Carbon Copy of the emails exchanges:
> --- Jeff schrieb am So, 20.3.2011:
> Von: Jeff
> Betreff: EMAX / Problem
> An: kingbalbo
> Datum: Sonntag, 20. März, 2011 18:26 Uhr
> Hi,
> Regarding to your post on the HxC Floppy Emulator forum:
> I send you this os file for emax. Can you try it ?
> Best Regards,
> Jean-François DEL NERO
>Selon kingbalbo:
> Hi,
> thank you for your quick answer!!
> i have tried your file but he shows me als disk not formatted.
> thanks in advance and best regards
> eric
>----- Ursprüngliche Nachricht -----
>Von:hxc2001
>An:Eric Balbo
>Betreff:Re: AW: EMAX / Problem
>hi,
>How react the emulator when the emax is accessing the disk ?
>How react the emulator leds ? What is displayed on the LCD ?
>which jumper setting have you ?
>Best Regards,
----- Original Message -----
>From: <kingbalbo>
>To: <hxc2001>
>Sent: Tuesday, March 22, 2011 12:25 PM
>Subject: AW: Re: AW: EMAX / Problem
> Okay my fault i had the jumper on the b drive.now it works!thanks a lot! Greetings eric
hossegor
Post by hossegor »
i have an Emax and i am Trying to hook it up with drive.
Could you possibly also send me a mail with the HF file to test ?
Thanx and regards
Marc
hossegor wrote:Hi Jeff,
Thanx and regards
Marc
Done !
juno6
Post by juno6 »
Now it works here too!
Well done Jeff, and thanx.
Cheers! :D
tabarnak
Post by tabarnak »
Salut, possible de m'envoyer une image de l'OS ?
