does the HXC work on the following computers?
lucifershalo
Post by lucifershalo »
Tandy COCO 2
SPECTRUM 128k +2
TI99-4A
ATARI 800 XL
MATTEL AQUARIUS
COLECO ADAM
SPECTRAVIDEO SV 328
ORIC ATMOS
I will buy it mainly for my MSX2
but if I can use for my other computers....
freaktmp
Re: does the HXC work on the following computers?
Post by freaktmp »
All these computers lack a floppy disk controller. If you can find controllers for these, most of them will probably work with HxC. The TI-99/4A and Oric are confirmed to work fine.
Take a look some pictures I have with an Oric-1 and a Cumana FDD controller:
https://hxc2001.com/floppy/forum/viewtopic.php?f=2&t=472
lucifershalo wrote:Tandy COCO 2
SPECTRUM 128k +2
TI99-4A
ATARI 800 XL
MATTEL AQUARIUS
COLECO ADAM
SPECTRAVIDEO SV 328
ORIC ATMOS
As already said, if you have a FDC with these machine, the emulator should works without problem.
already tested&working :
SPECTRUM 128k
TI99-4A
ORIC ATMOS
robert2098
Post by robert2098 »
lucifershalo wrote: ATARI 800 XL
If you have a XF551 diskdrive, you should be able to replace the drive mechanism with the HxC. The XF551 uses internally a standard drive unlike the 1050 diskdrive.
Otherwise take a look at the SIO2SD (available from lotharek too) or SDRIVE. These devices directly connect to the SIO bus without needing a floppy controller.
Robert
