Different starting sector ID on one track
arpruss
Post by arpruss »
Is there a way to specify a different starting sector ID on a special track for HXC raw images? In FlashFloppy one can have an IMG.CFG file that has something like:
tracks=0-78
id=1
tracks=79
id=97
Re: Different starting sector ID on one track
are you talking about the hxc tool or the hxc gotek firmware ?
the hxc software uses an xml file to specify the raw format.
arpruss
Post by arpruss »
Sorry I wasn't clear. I was talking about the firmware. Yes, I know I can use an XML file to generate an HFE file that has different starting sector IDs for different tracks, but it would be convenient to be able to directly use raw images with different starting sector IDs for different tracks, as it's easier to work with raw images than with HFE files on one's computer. (Of course, one can convert HFE to RAW and back, but it would be nice to be able to avoid that step.)
To have the full context, which tool on the pc force you to use the raw format ?
arpruss
Post by arpruss »
Jeff wrote: Sun Apr 19, 2026 4:05 pm To have the full context, which tool on the pc force you to use the raw format ?
No tool forces me to use raw format. This is for my HP 1653B oscilloscope. I use my lifutils.py python script to manipulate raw LIF images, and the script will launch hxcfe automatically to convert hfe to and from raw as needed. However, it would decrease friction for users of the script if they didn't have to install hxcfe. Moreover, I do a lot of development for this device, and the extra pair of HFE-RAW conversions whenever I change a file on a LIF volume slows things down a bit.
I've tried to use FlashFloppy, but it doesn't seem to work as reliably as HXC. I was able to boot the scope from an HFE file, but then the scope's file utilities didn't recognize the volume.
i should be able to add this raw support. let me check/update the code :wink:
arpruss
Post by arpruss »
Thanks, that would be great! Maybe the best thing to put in the custom firmware generator would be to have a section where you can put in special parameters for a specified range of tracks/sides (e.g., different starting sector ID, different number of sectors per side?).
In case anyone is curious, the specifics on my HP unit are as follows. The ROM code in the HP unit for reading/writing disk data checks if the track is 79. If it is, it uses 97 as the starting sector ID number; otherwise, it uses 1. Otherwise, track 79 is like tracks 0-78: five 1024-byte sectors per side. Sector 98 of track 79 side 0 stores a few crucial bytes of information about the the disk format, like the number of sectors per track, the size of each sector, etc.
arpruss
Post by arpruss »
Jeff wrote: Mon Apr 20, 2026 10:28 pm i should be able to add this raw support. let me check/update the code :wink:
Can I help with testing in any way?
arpruss wrote: Mon May 11, 2026 4:06 pm
Sure !
Here it is :
https://hxc2001.com/download/floppy_dri ... ek_Raw.zip
this should work "almost" out the box :
The img file must be sized to 819200 bytes (present in the zip)
and once flashed clear the internal settings from the menu to get the default in-firmware settings.
arpruss
Post by arpruss »
That works great! Thanks so much! (Sorry to have take so long to respond. I was traveling.)
Can you roll the different starting sector ID for a track into your customizer? I'd like to be able to use it with some of the other custom options. (E.g., hide extensions and ignore file size of image; the "ignore file size of image" is so that I can use 254 track images, with a magic track 79, for bigger storage; I currently do that with hfe files and it works well with a patch to the OS.)
