Can't update .. Bad UPD File header!
kahtan
Post by kahtan »
Hi jeff,
i have firmware version V0.2.0.0
i try to update to the new version V1_3_0_4
but i have error 5 Bad UPD File header! (bad file) :(
even when i try to update the bootloader HxC_SD_Bootloader_V1_0TOV1_1
i get the same error :(
please help
Kahtan :wink:
emrezanbak
Post by emrezanbak »
-> Format SDCard
-> Press Left and Right buttons before power up and keep it pressed at least 1 seconds at power up.
Regards.
Re: Can't update .. Bad UPD File header!
kahtan wrote:Hi jeff,
please help
Kahtan :wink:
The prototype firmware are incompatible with the actual version.
The prototype version aren't supported anymore.
To get the right firmware get a chip from Lotharek: http://www.lotharek.pl/
kahtan
Post by kahtan »
can i get only programmed PIC or i have to buy the complete kit?
Kahtan
kahtan wrote:Hi Jeff,
Kahtan
Ask this directly to Lotharek.
lotharek
Post by lotharek »
PICS will not be sold separetely
Complete device or KIT - pcb +PCB
..... Atari Roxxx !!!
