HXC SD MAX with SW v1.8.2.40
AwakeninfStar
Post by AwakeninfStar »
I aquired my LOTHAREK HXC SD MAX from Amigashop.eu some years back, but after several years i do not know where the User Manual is.
Would you please share the link?
The Emulator has SW version 1.8.2.40 installed
I use the SD MAX with my Amigas on the bench
Should I upgrade the SW? If so, how do I do it, and where can I download the new SW revision?
Kind regards
Joao Vaz Martins
Re: HXC SD MAX with SW v1.8.2.40
All is available on the main website :
https://hxc2001.com/download/floppy_dri ... tor/#sdhxc
