Converting from SCP / HFE to RAW IMG on Mac 800K
jimjamyaha
Post by jimjamyaha »
Encountering an issue where if I load a disk image in SCP or HFE to then convert to RAW Img thge output file is 0kb.
Can convert from SCP to HFE no issue. But cannot convert from SCP or HFE to RAW Img.
Works on other files - but not on 800k Mac Floppy images created as SCP via greaseweasel.
Am I missing something obvious here?
James.
Re: Converting from SCP / HFE to RAW IMG on Mac 800K
Yes by default the GCR sectors are not enabled in the raw exporter. I will add some config file option to enable this.
