Stuck at "Reading FAT.."
mikedean
Post by mikedean »
My Hxc is stuck at "Reading FAT.." prompt. I have tried several low level format tools, format in Windows XP to FAT32, tried several different types of images, etc. I am using a Sony 4GB SDHC card with Rev C Hxc. All software is latest version. CFG file is present on card. I am not sure what the next step is...
Re: Stuck at "Reading FAT.."
mikedean wrote:My Hxc is stuck at "Reading FAT.." prompt. I have tried several low level format tools, format in Windows XP to FAT32, tried several different types of images, etc. I am using a Sony 4GB SDHC card with Rev C Hxc. All software is latest version. CFG file is present on card. I am not sure what the next step is...
Unfortunately the only last thing to do is try another SDCard.
Can you give me the exact sdcard model ?
EDIT : try this beta firmware
https://hxc2001.com/floppy_drive_emulat ... 3_1_0B.UPD
mikedean
Post by mikedean »
Thanks Jeff. I will try another card. The card I am having problems with is a Sony SDHC 4GB with MMBGS04GWMCA-MB D4DCC0110000 SF4C4 on the back. I will also load that newer firmware and see if it work.
Mike
mikedean
Post by mikedean »
I tried a SanDisk 4GB SDHC card and no more problems. For some reason Sony is not working in Hxc. I will load new firmware and give feedback. Thanks.
mau_rizio
Post by mau_rizio »
On wich system are you having problem with the Sony card?
mikedean
Post by mikedean »
mau_rizio wrote:
mikedean wrote:
Jeff wrote: Unfortunately the only last thing to do is try another SDCard.
Rev C
mau_rizio
Post by mau_rizio »
Rev C[/quote]
I mean the computer type: amiga, st, etc.
I'm asking because i'm having problem with a certain sandisk sd but only with msdos pc.
But the last firmware seems to solve the problem :)
mikedean
Post by mikedean »
mau_rizio wrote:
Rev C
But the last firmware seems to solve the problem :)[/quote]
Oh. I tried different systems. Atari ST, E-MU SP1200, E-mu EMAX. None worked with Sony.
mikedean wrote: Oh. I tried different systems. Atari ST, E-MU SP1200, E-mu EMAX. None worked with Sony.
About the E-MU SP1200, is it working with the hxc floppy emulator ?
