Reading files issue
wavetable808
Reading files issue
Post by wavetable808 »
I just got my 1200 back from a service and I’m having an issue loading sounds from the floppy emulator. When I turn it on it by default loads and reads the file labelled DSKA0000.HFE. I have a large number of HFE files all in the root directory (all files on the SD card are in the root directory). When I select the right button on the emulator it reads through 10 files from DSKA0000.hfe to DSKA0010.hfe and then it returns back to the DSKA000.hfe file. So, I can’t access any file other than these 10. Also the left and middle button don’t seem to do anything.
Although I’m not sure, I think I have to have the file DSKA000.hfe loaded as the last file before I turn it off otherwise I get the error ‘loading diskette’ when booting and nothing loads.
Does anyone have any idea as to what the problem might be? Many thanks.
wavetable808
Re: Reading files issue
I think I figured out that the reason I can only read the DSKA files is that I was using the indexed config files. However, now I get an error on load up saying 'insert diskette'. I've re-tried everything with three SD cards with no luck.
To fix the reading problem - I swapped to the normal config files and reloaded the files DSKA000 0 and DSKA0001 which seems have the OS1.2 on them.
So the issue is fixed ?
