saving problem in SP1200
seoulASMR
Post by seoulASMR »
hello guys
i programmed gotek hxc for my SP 1200
it was Artery type, so i use USB A - USB A method
everything was OK, it works.
but i can't saving sound.
everytime i try to save sound, display shows
"DiskNotFormatted"
then i try to format the disk, it doesn't work.
i tried every jumper, but it only works for S0 and M0
the UPD file is latest version.
also i use 'Index mode' for it
my gotek is generic 3 letter gotek.
seems like it works because it load sound and OS
only problem is saving.
i tried searching same problem in this community,
there's someone got same problem in 2017.
i tried v3xx UPD file, it makes blank display
so i re-update for latest UPD file for it.
what should i do for it?
i already spent many time for it
can you guys help me?
thank you
seoulASMR
Re: saving problem in SP1200
Post by seoulASMR »
now, i got more weird problem.
i updated gotek with old firmware.
i tried v3_8_3_1a.
that can SAVE, but it doesn't makes actual file. or not working.
here's how my gotek works.
i load disk 000.
that disk is OS disk.
and 1.4 seconds of samples in there.
i choose disk 010 which is blank disk,
and i copy the OS to the 010.
also save sequence and sounds.
it shows 'complete' on gotek's display.
then i clear memory and load disk 010.
display shows complete but
there's no sounds, no squence.
SP still have 100% sequence and 10seconds memory
i think it's not create actual file.
i turn off the SP and turn on with disk 010,
it's not working. because the OS file is not working.
i tried early V4 UPD files too and S0, M0 jumper both.
same result.
it shows like possible to saving and creating files,
but the file is empty. not actual file.
looks like it works,
because when i try to save something it shows complete.
but still have saving problem.
loading is perfect everytime.
it can load all factory sound disk or OS disk.
i really want to save my sound and sequence file.
please help me.
can you guys let me know what kind firmware UPD file do you use?
mine is early V4 UPD now.
i tried late V3 to early V4 UPD,
they can save but that makes not working file. feels like empty file.
what can i do for fix it?
If you have an AT32F415 Gotek i recommend to change it for one of these solutions :
- An true SD HxC Floppy Emulator
or
- An STM32F105 Gotek
or
- An AT32F435 Gotek.
The AT32F415 has just not enough ram to be really reliable.
