How to switch images with file selector for windows
AdmDecker
Post by AdmDecker »
I have the HXC SD Rev. C Firmware: 1.8.2.40
I'm trying hard to figure out on how to switch images wihout using the buttons on the PCB.
The emulator is connected to my Windows XP machine.
The software HXCFEMGR.exe is working but very confusing.
For example:
Why is an USB Stick required (/disk:##), when the emulator has an SD card on board ?
What is the usage of the slots ?
Regardless what image I selected (with F8,F9 or F10), it has no effect to the emulator.
Can anyone help ?
Re: How to switch images with file selector for windows
AdmDecker wrote: Mon Nov 04, 2024 6:05 pm Hi,
For example:
Can anyone help ?
The windows HXCFEMGR.exe software doesn't control the hxc emulator. The purpose is to edit the sdcard/usb stick slots configuration.
The slot mode was designed for emulator without lcd screen.
AdmDecker
Post by AdmDecker »
So, is there a fileselector software for windows?
It would be great to step through the code in VS6.
AdmDecker wrote: Mon Nov 18, 2024 12:46 am So, is there a fileselector software for windows?
Under windows you need to develop a driver to control / access the machine/pc floppy disk drive controller.
