Yamaha QY700 'bad disk' on write
NatoPotato
Post by NatoPotato »
Hi there friends,
I was curious to know if anyone could help me. I have a QY700 with a gotek installed, the firmware loaded on to the gotek is HxCFEUSB_V5_2_2_2a.
I do not have a problem reading files and transferring from USB to the QY700, however, when I try to write from the QY700 to a USB I get the bad disk error.
Any help would be greatly appreciated.
Thank you :)
davisramos32
Re: Yamaha QY700 'bad disk' on write
Post by davisramos32 »
hello,
Hello, can you tell me what emulation method you are using?
What file do you use, what happens is that I have a psr-6700 and I can't write from the disk explorer, let's see if the file I use works for you
NatoPotato wrote: Thu Oct 17, 2024 7:26 am Hi there friends,
Thank you :)
Which gotek have you ? -> remove the stick, press both buttons and go to the version sub menu. an hardware code will be displayed.
