ASR-X - Disk write failed!
Mirosh
Post by Mirosh »
Hi everyone,
after spending too much hours on it I get "Disk write failed!" from the ASR-X (not the pro) when trying to save my work.
I have succesfully flashed the HxC Software to the Gotek, made some configurations and loaded one original ASR-X disk to the USB Stick.
And I am able to load the files from the disk. What I can't do is saving or formatting the disk.
The Write Protection is off in the HxC menu on the Gotek.
Any hints where I can search for a solution? Jumper is on S0.
thanks!
Mirosh
Re: ASR-X - Disk write failed!
Mirosh wrote: Sat May 25, 2024 1:24 am Hi everyone,
thanks!
Mirosh
Try to use some .IMG files instead
I also recommend to use AT32F435 Goteks or at least the STM32F105 Goteks.
If possible avoid AT32F415 Goteks, they are problematic. (no enough internal memory)
