Firmware Update Error "E01"
tikidays
Post by tikidays »
Hi guys, hope you can help.
I inherited and atari with a GoTek, its running firmware FF-3.37 and it worked with .ST files fine. Its a USB Stick version, and displays "F-F'"on power up with no stick, indicating it has a bootloader installed.
So I attempted to upgrade, and things went wrong.
When I copied over the latest File Selector it asks me to upgrade the firmware. It no longer makes it to the selector if you bypass this message saying "ERROR: Bad Config file version !" , which is odd as this is the one that came with this File Selector.
However loading the firmware for:
- Gotek with 7 segments screen, without rotary.
Generic_Gotek > Standard_Firmware > HxCFEUSB_V5_2_1_2a.UPD
Engaging "Upg" by holding the two buttons down, results in an error with "EO1" displayed on the LCD.
Whats my next step to try?
Thanks in advance!
Re: Firmware Update Error "E01"
It seems that your Gotek was shipped with the factory firmware. you first you need to install the HxC firmware : Then you will receive the correct files.
https://hxc2001.com/store/
