TI-990 floppy with 288 Bytes per sector.
JimHearne
Post by JimHearne »
Hi All,
Is it possible to get the HxC to support 288 byte sectors as used by Texas Instruments on the FD1000 8" disc drives used on the TI-990 systems
At a first look seems that the HxC bytes per sector are fixed to powers of 2 so 256, 512 etc and can't be set to another value.
I have both a HxC2001 emulator and a Gotek so either of those could be used.
These are the details of the FD1000 disc format:
I have more details about gaps etc if the 288 bytes per sector can be solved.
FD1000 format
DSDD
MFM
288 byte / sector
26 sectors / track
77 Cylinders /disc
7488 bytes per track
1,153,152 bytes per disc
Many thanks,
Jim
Re: TI-990 floppy with 288 Bytes per sector.
This machine probably use a non standard sector format. Is there it's low level format description available somewhere ?
