Should I convert my Kryoflux images to HFEv3? ...and what about weak bits protections?
sofakng
Post by sofakng »
Should I convert my Kryoflux images to HFEv3? (or another format)
It looks like HFEv3 is listed as an experimental format so I'm a bit concerned but I am interested in a single-file format to make it easier to manage these images.
Also, are there any image formats that support weak bits copy protection?
Re: Should I convert my Kryoflux images to HFEv3? ...and what about weak bits protections?
sofakng wrote: Sat Oct 14, 2023 5:11 pm Should I convert my Kryoflux images to HFEv3? (or another format)
No, you shouldn't. For sure keep the stream files !
All others formats are not good enough to fully preserve the images.
