Issue with Rev C HxC SDcard emulator
huggyone76
Post by huggyone76 »
Hi !
One of my two Rev C HxC goes into troubles ;-)
After a firmware update, I can select a floppy image, but no way to run this.
So, just to try, I swapped the two PICs between my two Rev C and so, the issue swapped with the PIC ;-)
I'm not able to update firmware anymore it seems... So, what can I do ?
Thank you
Re: Issue with Rev C HxC SDcard emulator
huggyone76 wrote: Sun Jun 04, 2023 6:02 pm Hi !
Thank you
Try to update it from another machine, and check the +5V voltage on the previous machine.
