Lotharek HXC Rev F not loading OS completely (ESP 16+)
kadoat
Post by kadoat »
I have an Ensiniq EPS 16 Plus with the Lotharek HXC Rev F SD floppy drive emulator installed.
I am unable to get the OS to load beyond the first few 'clicks' (about 09/80). The keyboard then outputs an error code: "ERROR 131 - REBOOT ?"
My SD card has been formatted for FAT32 and his the 'QuickInstall_FloppyDiskImages' downloaded from Lotharek's website.
The ribbon cable has been plugged in with the colored wire on PIN 1 and the DIP switch for ID0A is on. This appears to be correct for the EPS 16 Plus
I have tried the other OS HFE images but I still get the same error
Any ideas?
Re: Lotharek HXC Rev F not loading OS completely (ESP 16+)
kadoat wrote: Sat Jun 03, 2023 7:45 pm I have an Ensiniq EPS 16 Plus with the Lotharek HXC Rev F SD floppy drive emulator installed.
Any ideas?
After a quick search it appears that this ERROR 131 is an "illegal instruction" exception from the EPS 68000 CPU. A power supply issue appears to be a common cause.
