Add files to HFE file for Amstrad
huggyone76
Post by huggyone76 »
I owned several old computers and several HxC (SD or USB)
With my Atari STE, my Amiga, even my old PC, no problem to create a blank disk from the Disk Browser, select the good format and go ! After that, I can add personal files to the virtual disk and they appear on the disk when I load the file from the computers.
But... I don't know how to do that for my Amstrad CPC 6128.
Easy to convert .dsk to .hfe... But I don't know how to fill .dsk or .hfe files with Amstrad personal files.
Is there a solution ?
Thank you
Re: Add files to HFE file for Amstrad
Probably possible with some third parties softwares on DSK files.
huggyone76
Hi Jeff !
You’re right !
I got into the bad habit with my Amiga and ST of doing everything directly with the HxC manager :wink:
So there is a lot of tools which allow to work on dsk files under Windows :wink:
Thank you !
