Disk is write protected
Chepelin
Post by Chepelin »
Good afternoon, I come to you for help, I bought a Slim SD HxC Floppy Emulator RevA 211212 for my Amiga 500, it has FirmWare v2.1.6.20a and I use version 2023.1.12 of the Emulator Manager for Amiga. It works perfectly, the only problem I have is that it does not allow writing to any disk images that I have mounted, it gives me an error message "Disk is write protected"
I have tried several SanDisk Class 10 SD cards, with no write protection and can't write to any disc. What can be the solution? Thanks for the help.
Re: Disk is write protected
Is the file selector software working ?
Chepelin
Post by Chepelin »
It's correct the file selector works fine.
