HxC Floppy Emulator for Android?
test29
Post by test29 »
Is it possible to compile HxC Floppy Emulator to work on Android (on android tablet's)?
Thank you.
TFM
Re: HxC Floppy Emulator for Android?
Post by TFM »
test29 wrote:Is it possible to compile HxC Floppy Emulator to work on Android (on android tablet's)?
Thank you.
If the particular device has an standart shuggart bus, PC floppy bus, Amiga floppy bus then IMHO it should work.
Thank you.
No the question is : the converter can be ported on Android (http://www.android.com/)?
Well, if there are an ansi-c compiler available (gcc for example) on it, this should be possible.
bradn
Post by bradn »
I think you would need a way to compile C code to java bytecode, or to install normal c libraries and all that stuff on android. If I understand correctly, android is a butchered java running directly under the linux kernel.
cbrunschen
Post by cbrunschen »
bradn wrote:I think you would need a way to compile C code to java bytecode, or to install normal c libraries and all that stuff on android. If I understand correctly, android is a butchered java running directly under the linux kernel.
It's a little different than that, fortunately.
Android uses a modified Linux kernel; most user-visible applications run in the Dalvik virtual machine, and if you want to expose a UI, you basically need to have at least part of your application in that fashion, using the Android SDK .
However, you can also write C code, using the Android NDK.
The two – SDK and NDK – go hand-in-hand, so if you have part of your application that is/needs to be written in C, you'd end up using both - the NDK for the C bits, and the SDK for the UI-and-similar bits.
Best wishes,
// Christian
